Старый 02.12.2009, 23:05   #1
mfp: TFS2010 - a long term successor of Visual SourceSafe
Источник: http://blogs.msdn.com/mfp/archive/20...ourcesafe.aspx
If you are using the version control integration features in Dynamics AX you may be using Visual SourceSafe as the version control provider. If you do, you are probably aware that Visual SourceSafe has been in maintenance mode for several years. You may even be looking for a replacement - after all your source code is a valuable asset, and it needs a reliable and sustainable home.
Team Foundation Server (TFS) is the natural replacement offered by Microsoft - and it is also supported by Dynamics AX 2009. However, TFS has so far been two complex and too costly to be a real alternative for smaller teams.
With TFS 2010 this is changing - for more information see these two blog posts:
http://blogs.msdn.com/bharry/archive...afe-users.aspx
http://blogs.msdn.com/bharry/archive...g-changes.aspx
emeadaxsupport: Debugging Microsoft Dynamics AX 2009 SSRS reports with Microsoft Visual Studio 2008 Blog bot DAX Blogs 0 26.07.2009 15:07
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM Plug-in Template for Visual Studio Blog bot Dynamics CRM: Blogs 0 27.10.2008 23:05
mfp: Late night discussion on software development #2: Estimation Blog bot DAX Blogs 0 18.01.2008 16:30
mfp: Sneak preview - Code Upgrade Enhancements Blog bot DAX Blogs 0 02.03.2007 20:46
mfp: Setting up Visual Source Safe and Dynamics AX 4.0 Blog bot DAX Blogs 0 28.10.2006 16:47
Часовой пояс GMT +3, время: 10:48.
