Старый 19.11.2009, 14:05   #1
dynamicsaxtraining: Create new company. Demo data
Источник: http://www.dynamicsaxtraining.com/dy...pany-demo-data
Hi there! What first we should create in Axapta? I will tell you about different business process and their implementation in Axapta so we should have one data to work with.
In this training lesson we will create new company in Dynamics AX (Axapta) and import demo data.
Create new company
  1. Go to Administration -> Company accounts. The Company form will be shown
  2. Create new record (Ctrl+N). Populate fields: “AXT” in the Company accounts field, “Dynamics AX Training” in the Name of company accounts fieldCompany account
  3. Save the record (Ctrl+S)
Good, our new AXT company is ready.
Switch to AXT company:
  1. Click on the current company (placed in the bottom right corner). The Select company accounts forms will be shown
    Current company
  2. Select “AXT” record. And click Ok.
Axapta will change company from DAT to AXT.
Tip: when you login in Axapta next time you should change company from DAT to AXT again. You can setup other default company.
Let’s setup the AXT company as default company:
  1. Click on Axapta menu Tools -> Options…
    Tools menu
  2. The Options form will be shown. On the General tab find Start company accounts field and select AXT company. Close the form.
Import demo data.
  1. Download demo file and definition file. Extract and save these files in one folder
  2. Return to Axapta. Ensure that current company is AXT. Go to Administration -> Periodic -> Data export/import -> Import. The Import options forms will be shown
  3. Populate the File name field with path to downloaded demo file. Click Ok.
This process is time consuming. Approximately 10 minutes. When import is finished the message will be shown.
That is all! Our new AXT company with demo data has been created.
Let’s start create your first item.
Technorati Tags: create company, import demo data
emeadaxsupport: Query execution failed for data set 'Company' Blog bot DAX Blogs 0 28.10.2009 00:06
Microsoft Dynamics CRM Team Blog: Data Migration Manager Tips and Tricks Blog bot Dynamics CRM: Blogs 0 02.09.2008 22:05
Dynamics AX: Dynamics AX 2009 - Demo Data Released Blog bot DAX Blogs 1 11.07.2008 11:24
Arijit Basu: Demo Data for Microsoft Dynamics AX 2009 Blog bot DAX Blogs 0 09.07.2008 02:10
AX UK: Demo Data for Microsoft Dynamics AX 4.0 Blog bot DAX Blogs 0 07.11.2006 10:32
Часовой пояс GMT +3, время: 05:35.
