Старый 09.09.2008, 07:07   #1
gatesasbait: Report 'shape' control issues with PDF Printer class in Dynamics AX 4.0
Источник: http://gatesasbait.spaces.live.com/B...B9F5!253.entry
Good evening,
I had an issue with some reports not displaying properly when printed through the standard AX PDF printer class 'PDFViewer'. In reports where 'shapes' were used as background for normal 'string' fields, the shape would show, but not the field. That would happen only for some 'shapes', not all. However everything would show properly on-screen, as well as when printed on actual paper.
The issue is that 'shapes' on reports need to be placed first in their section (first from top to bottom) for the PDF printer to be able to display the text over the shape. It’s a back to front thing where 'back to front' corresponds to 'top to bottom' on the AX report section.
Moving all the shapes to the beginning (top) of their respective report sections solved the issue.
gatesasbait: Dynamics Ax 2009 SSRS report deployment under Server 2008 (deux) Blog bot DAX Blogs 0 11.02.2009 23:05
gatesasbait: Dynamics Ax 2009 SSRS report deployment under Server 2008 Blog bot DAX Blogs 0 11.02.2009 11:05
gatesasbait: Dynamics AX 2009 Report Deployment error Blog bot DAX Blogs 0 17.07.2008 20:05
gatesasbait: Automatic creation of a PDF from a customer invoice in Dynamics Ax 4.0 Blog bot DAX Blogs 0 28.04.2008 19:05
Часовой пояс GMT +3, время: 04:14.
