Старый 25.08.2008, 18:05   #1
msdynamicsax: VB script that test the com connector for Dynamics Ax 4.0
Источник: http://msdynamicsax.wordpress.com/20...ynamics-ax-40/
Some of you might have had problems testing the com-connector for Dynamics Ax 4.0 in an environment without IIS. The trick is to just create a new text file and rename it to something.vbs afterwards.
Edit the file and paste the following:
‘ VB Script to test the Axapta COM Connector.
Dim ComConnector
dim result
Set comConnector = CreateObject(”AxaptaComConnector.Axapta3″)
comConnector.Logon “”, “”, “”, “”
result = “Com Connector ” & comConnector.callStaticClassMethod(”xInfo”, “BuildNo”) _
                        & ” built on ” & comConnector.callStaticClassMethod(”xInfo”, “compilationDate”) _
                          & ” at ” & comConnector.callStaticClassMethod(”xInfo”, “compilationTime”)
msgbox (result)
comConnector.logoff
set comConnector = nothing
You should get a message box telling you the build num and date/time of the Ax installation. If not, you have a problem with the com connector setup.
msdynamicsax: Dynamics Ax 2009 SDK Blog bot DAX Blogs 0 13.08.2008 14:05
msdynamicsax: Upgrading a database from Ax 4.0 SP1 to Ax 2009 Blog bot DAX Blogs 1 13.08.2008 14:02
Khue Trinh: AX 2009 Quality Management - Quality Control Blog bot DAX Blogs 1 04.07.2008 16:01
Pokluda: SysTest part IV.: Test/Suite initialization and cleaning; Execution isolation Blog bot DAX Blogs 0 28.10.2006 17:43
Часовой пояс GMT +3, время: 15:47.
