Старый 08.12.2001, 03:30   #1
PlasticinE is offline
PlasticinE
Смотрящий поверх деревьев (Варварский отморозок)
243 / 10 (1) +
? Передвижение по записям в таблице
<Зохавано мудератором>
за неуплату
It's a dirty job, but someone's got to do it. So?
Старый 08.12.2001, 03:43   #2
Роман Кошелев is offline
Роман Кошелев
Продавец игрушек
Аватар для Роман Кошелев
433 / 73 (3) ++++
Lightbulb
Действительно, Антон описывал как заставить грид встать на нужную запись.
Твою проблему можно решить так:<pre><b>while</b> select * from tTable1
print tTable.name; <font color=green>// или любые другие действия</font>
</pre>
или так:<pre>select * from table1;
while (tTable1.<b>recid</b>)
next tTable1;
</pre>
где <b>recid</b> -- системный идентификатор записи
<hr>
<b>см. также "Руководство разработчика", "Select statement"</b><pre><font color=#AAAAAA>void SelectRecordExamples()
CustTable custtable;
//A customer is found and returned in Custtable
select * from Custtable;
// A customer with account number > “100” is found
where AccountNo > “100”;
/* The customer with the LOWEST account number > “100” is found,
that is, CBS with number 200. */
select * from Custtable order by AccountNo
next Custtable; // The next customer is read, i.e. Walt Disney
/* The customer with the HIGHEST account number
(greater than 100) is found: Pentagon */
<b>select * from Custtable order by AccountNo DESC
next Custtable; // The next record is read (DESC) = Ford Motor</b>
// The customer with the HIGHEST account number is found: Pentagon
select reverse Custtable order by AccountNo;
/*The customer with the “lowest” name and account number
in the interval ]100;1000[ is found. This is CBS. */
select * from Custtable order by NameRef
&& AccountNo < “1000”;
/* The COUNT select returns the number of customer accountnumbers (customers): 5 */
select count(AccountNo) from CustTable;
print Custtable.AccountNo; // Prints the result of the count
// (which is in AccountNo)
/* Returns the Sum of balances for non-blocked customers. The result is:
SUM: $1,060,000, stored in the Balance field
select sum(Balance) from Custtable
where Blocked == DebCreBlocked::No;
</font>
</pre>
С уважением, Роман Кошелев.
Фильтрование записей при "переходе к основной таблице" demID DAX: Программирование 10 18.11.2015 12:52
как сохранить запрос в таблице kitty DAX: Программирование 13 19.11.2007 20:16
Переход на правильную запись при Переходе к основной таблице. Anais DAX: Программирование 11 29.06.2004 19:16
фильтр по связанной таблице mick_777 DAX: Программирование 13 21.08.2002 16:00
Часовой пояс GMT +3, время: 15:24.
