Dual-write setup from Lifecycle Services fails at Application step
Источник: http://alexvoy.blogspot.com/2024/08/...lifecycle.html
============== If you receive the issue with applying Dual-write for your D365FO environment following the standard procedure, you may need just to change one database parameter. Open SQL MS and switch this flip to True and keep default values for your database. Now you can resume the process. Источник: http://alexvoy.blogspot.com/2024/08/...lifecycle.html
