Старый 11.05.2020, 16:11   #1
crmtipoftheday: Tip #1354: UI Flow: Setting document typeface properties
Источник: https://crmtipoftheday.com/1354/ui-f...ace-properties
I recently was evaluating using UI Flow RPA to automatically print barcode labels. Using Microsoft Word or Wordpad and a freely available barcode TTF, I passed the barcode value to the document and hit the print button.
All worked as expected, except I could not get the flow to properly record selecting the correct font. Mouse cursor movements are not captured, and in Word the recently used fonts list dynamically changes in length, so I could not dependably select the correct font.
I resolved the issue by creating a document with the desired font and font size already selected, then changing the application path in the UI flow to the file path of that document, rather than the application file.
The result is Word or WordPad are launched with the correct font selected, and the barcode was created successfully.
The also seems to be a good solution for getting past the recent items screen in Word and other Office 365 applications with RPA–don’t launch the application, launch a file associated with the application.
Cover photo by Alexander Andrews on Unsplash
crmtipoftheday: Tip #1276: Do my Dynamics 365 users need a Microsoft Flow license? Blog bot Dynamics CRM: Blogs 0 21.06.2019 19:12
crmtipoftheday: Tip #1124: Flow Approvals May Be Exactly What You Need Blog bot Dynamics CRM: Blogs 0 25.06.2018 12:11
stoneridgesoftware: PrecisionForms for Document Management in Dynamics AX Blog bot DAX Blogs 0 14.09.2017 19:11
Часовой пояс GMT +3, время: 15:46.
