waldo: VSCode & Snippets
Источник: https://dynamicsuser.net/nav/b/waldo...scode-snippets
============== I did apoll recently during one of my sessions – and I was surprised that about halfof the people don’t regularly use “snippets” in VSCode.. . Well,some of you probably know that I’m a big fan of snippets. Whoever has joined one of my sessions of thelast couple of years where I was talking about VSCode, or was working withVSCode .. most probably, I was talking about, showing or using snippets. Honestly,I can’t live my life in VSCode without snippets. It would be so much less efficient .. . VSCode wouldn’t be much more than a notepadthat is hooked up with Source Control in that case. Back in2017, I even spent quite some time in my session on NAVTechDays about snippets. I’ll share the session at the end of thispost… How to manually create snippets? Iwould be able to explain you how to manually create snippets – but Iwon’t. Because it is actually alreadybeautifully explained on the documentation section of VSCode here: https://code.visualstudio.com/docs/e...efinedsnippets Basically,user defined snippets …:
My snippets There ismore :-). I have been creating lots ofsnippets in myextension. I admit, I copiedMicrosoft’s snippets and improved them – but I also have created lots of newsnippets. Ones that I use a lot in termsof “design patterns”, but also for implementing code that I’m notused to, and don’t want to forget (like the assisted setup). If you install my “CRS AL LanguageExtension”, you’ll recognise my snippets with “waldo” in the suffix: ![]() "CRS.DisableCRSSnippets": true(if youmight wonder, you can disable Microsoft’s snippets as well ;-)). Tools that can help you to create snippets Irecently was pointed to this tool: https://snippet-generator.app/ . When you are creating yourVSCode snippets, simply paste the text that you want to convert to a snippet tothis tool, and you immediately get it converted to a JSON representation for aVSCode snippet. I tremendously speeds upthe creating of a snippets from minutes to seconds ;-). On theother hand, there is another tool that you can install in VSCode: the snippet-creator. It basically gives you a command that willconvert your selected text into a user-snippet of the language of your choice: ![]() Some questions I get a lot Where are snippets stored? The user-defined snippets that you create, are stored here: %USERPROFILE%\AppData\Roaming\Code\User\snippets. The snippets that come from an extension, are stored here: %USERPROFILE%\.vscode\extensions\\snippets Can I disable snippets? Well,no. You can’t in any decent way (that Iknow of) disable snippets. I know I wastalking about a setting in my extension, and yes, that’s a way, but it’s not adecent way ;-). In fact,what I do in that extension, is simply rename the “snippets” folderto “snippets-disabled”. Thatway, the extension is not able to find the snippets, and won’t show themanymore. The downside of this is that itwill give errors in the background because it’s not able to find the snippetsanymore, like: ![]() Can I change snippets? Well, noagain. To be fair: you CAN change asnippet in the extension folder, but do know that when the extension isupdated, it basically is going to overwrite the snippets … and you lost yourmodification. So in my opinion, that’snot an option. That wasit! Hope you’re into snippets and thisblogpost was completely useless. If not,at least I hope this got you triggered a bit ;-)! The only thing left for me is to share theNAVTechDays session I was talking about earlier: Источник: https://dynamicsuser.net/nav/b/waldo...scode-snippets
