Старый 03.09.2019, 10:12   #1
Ventainais is offline
Ventainais
Ax 12. R3 SSRS report BusinessLogic class method changes are not reflected in the report
Hello all!
I updated code in BusinessLogic class, recompiled it, redeployed the report and compiled INC CIL but the changes are not reflected in the report.
In the report I have a text-box with expression "getGroupTotal()" which returns an integer value 10 for testing, but when I generate the report it shows that methods previous calculated value.
If I change the expression to show any other variable without using BL methods then the report shows the change.
I tried to delete Visual Studio and Ax cache files, AOS restart but that didn't helped.
I would appreciate any help
If any other information is needed to help me, please ask.
Старый 03.09.2019, 10:55   #2
Pandasama is offline
Pandasama
467 / 140 (5) +++++
Did you try to redeploy VS-project with your modified business logic class ?
Check, if business logic dll on SSRS server updated. You even can delete this dll it from SSRS, and then redeploy business logic class from VS - to ensure that DLL will be created again
Старый 03.09.2019, 11:17   #3
Ventainais
To deploy a report I always use MS Dynamics AX 12 Management Shell command
"Publish-AXReport -Id sqlservername -ServicesAOSName aosname -ServicesAOSWSDLPort 8101 -ReportName MyrReportName" but if I try to deploy the BL class from VS I get an error message:
I'm not sure how to find the dll in SSRS server and/or I have the rights to do so.
The server administrator can't help me with this ether.
Последний раз редактировалось Ventainais; 03.09.2019 в 11:19.
Старый 03.09.2019, 15:59   #4
Ventainais
Problem solved.
Solution.
Export AOT/Visual Studio Projects/C Sharp Projects/yourProjectName.businesslogic
Delete it from AOT and import it back again.
Redeploy the report.
dynamicsaxse: May-June 2017 release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 21.06.2017 00:12
emeadaxsupport: AX Performance - Analyzing key SQL Server configuration and database settings Blog bot DAX Blogs 0 28.09.2015 14:11
emeadaxsupport: AX Performance Troubleshooting Checklist Part 2 Blog bot DAX Blogs 0 09.09.2014 16:11
bojensen: Use a Dynamics AX display method in SSRS report | Arjen Stolk Blog bot DAX Blogs 0 20.03.2013 01:11
Часовой пояс GMT +3, время: 01:42.
