Старый 13.06.2019, 14:11   #1
crmtipoftheday: Tip #1273: Microsoft Flow dynamic content experience
Источник: https://crmtipoftheday.com/1273/micr...nt-experience/
When creating a flow, when you select a field in a step, you are normally presented with the dynamic content panel. This lets you select field references from your previous steps or write an expression.
But sometimes when you click on a field you will see a less functional list of parameters appear underneath the field.
This is a less user friendly experience because it can be difficult to figure out which field to select (as you can’t see the full name value) and it’s not clear where to enter an expression.
The reason there are two different experiences is to make the Flow maker experience work on small screen sizes. where you don’t have room to display the full dynamic content panel.
If you are seeing the second experience, maximize your browser window and you should see the full dynamic content panel.
Cover photo by Khaled Reese from Pexels
stoneridgesoftware: Email Alerts on Power BI Dashboards with Microsoft Flow – Better Together Blog bot DAX Blogs 0 19.01.2017 20:11
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 12 Blog bot Dynamics CRM: Blogs 0 30.01.2013 01:11
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 7 Blog bot Dynamics CRM: Blogs 0 27.03.2012 02:11
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 4 Blog bot Dynamics CRM: Blogs 0 24.09.2011 01:16
Часовой пояс GMT +3, время: 10:53.
