Старый 06.05.2019, 00:13   #1
shashidotnet: D365 FO EDMX / OData trimmer – Make your metadata smaller
Источник: https://shashidotnet.wordpress.com/2...adata-smaller/
Creating a .Net application with the OData metadata from your D365 application can generate a large file
A typical metadata file (edmx) retrieved from https:///data/$metadata will return a file of almost 17MB. Turn that into a c# file using the T4 templates and the C# source file is almost 64MB.
After spending some time trying to reduce the EDMX file to only the entities I require (and a lot of nagging by my friend) I created a way to remove the excess entities from here. Result is a smaller EDMX file, and a more lightweight .Net application for you.
Reference this Trimmed EDMX file in your T4 template
The project and instructions can be found at my Github project EDMXTrimmer: https://github.com/shashisadasivan/EDMXTrimmer
Advertisements
D365 for FO Tips&Tricks: Calling PowerApps from D365 for Finance and Operations Blog bot DAX Blogs 0 14.08.2018 17:11
D365 for FO Tips&Tricks: Unlocking ‘RU’ country code functionality in D365 for FO Blog bot DAX Blogs 0 14.08.2018 17:11
D365 FO - Ошибка: Module 'AAA' is missing the following dependencies: 'BBB' MarinaAX DAX: Программирование 4 21.07.2018 22:42
sertandev: Using .NET attributes for D365 FO child class constructors Blog bot DAX Blogs 0 04.04.2018 14:11
erconsult: Copy-paste automation in D365 FO with a keyboard emulator Blog bot DAX Blogs 5 10.01.2018 13:42
Часовой пояс GMT +3, время: 19:23.
