Старый 26.01.2018, 23:12   #1
crmtipoftheday: Tip #1062: When recompile is not enough
Источник: https://crmtipoftheday.com/1062/when...is-not-enough/
As was mentioned in the Tip 1058, the most simple and easy way to deal with TLS 1.2 in your code is to recompile it with .net 4.6.2+.
As David “Xrm.Tools” Yack discovered, it may not work for some of the existing projects. The issue is that, when the framework version changes in Visual Studio there is a secondary setting in web.config that can override that!
The httpRuntime target framework stays the same when you change the project settings – it has to be manually updated. If you don’t, then the project will really be running as 4.5.2 while deployed as 4.7. If your project tries to connect to Dynamics 365 version 9 (where TLS 1.2 is enforced), you will receive seemingly unrelated errors, and/or unexpected results from some function calls.
It’s the small things that bite you hard! – David Yack (c) 2018
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
crmtipoftheday: Tip #1041: Make Dynamics 365 data import less rigid Blog bot Dynamics CRM: Blogs 0 11.12.2017 03:41
crmtipoftheday: Tip #1013: Include attributes that are not there Blog bot Dynamics CRM: Blogs 0 01.11.2017 16:11
Быстродействие метда TaxParameters::find Ace of Database DAX: Программирование 7 01.06.2017 11:46
Часовой пояс GMT +3, время: 05:58.
