Старый 31.01.2017, 23:14   #1
mfp: Subscribing to onValidatingWrite
Источник: https://blogs.msdn.microsoft.com/mfp...lidatingwrite/
Most event handlers are straight forward. One exception is when subscribing to a table’s onValidated and onValidating events. The trick is to realize that the DataEventArgs instance passed to the event handler, is a validateEventArgs – a specialization of DataEventArgs. Here is a template to use: [DataEventHandler(tableStr(<TableName>), DataEventType::ValidatingWrite)]public static void <TableName>_onValidatingWrite(Common _sender, DataEventArgs _e){    boolean result = true;    ValidateEventArgs validateEventArgs = _e as ValidateEventArgs;    <TableName> <table> = _sender as <TableName>;     if (<validation>)    {        result = checkFailed(“Validation failed”);    }    validateEventArgs.parmValidateResult(result);}   The platform will keep raising the...
mfp: What is new in X++ in AX7? Blog bot DAX Blogs 2 10.02.2016 00:29
mfp: Technical Conference 2011–Wrapping up Blog bot DAX Blogs 0 18.11.2011 16:11
mfp: Dynamics AX EMEA Technical Conference 2011 Blog bot DAX Blogs 0 21.09.2011 18:11
mfp: AX models - Part 4 - Working with models inside MorphX Blog bot DAX Blogs 4 26.11.2009 16:55
mfp: Sneak preview - Code Upgrade Enhancements Blog bot DAX Blogs 0 02.03.2007 20:46
Часовой пояс GMT +3, время: 20:31.
