Старый 20.10.2016, 12:11   #1
organicax: Working with the workflow editor download in AX7
Источник: https://organicax.com/2016/10/19/wor...wnload-in-ax7/
If you are working with workflow in AX7 then editing them requires a .NET component that will download when you start to edit the workflow. Seeing this is a download component in rare cases you might have issues with the downloaded files. If you get a message something like “application cannot be started. Contact the application vendor.” then something might have happened with the downloaded application files so you might want to clean them up.
Here is a quick overview.
AX7 Build 7.0.4230.16130
The command you see in the video is
rundll32 dfshim CleanOnlineAppCache
Cheers
Lachlan
Filed under: Workflow
organicax: Workflow performance report Blog bot DAX Blogs 0 23.09.2016 10:11
organicax: Deleting a workflow configuration that has running instances Blog bot DAX Blogs 0 26.03.2016 04:15
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Microsoft Dynamics CRM Team Blog: Workflow E-mail Utilities Blog bot Dynamics CRM: Blogs 0 16.12.2008 23:05
Часовой пояс GMT +3, время: 02:47.
