Старый 03.10.2016, 23:12   #1
emeadaxsupport: Clustered SQL Server instance – Example AX TEST environment configuration concepts and points of interest
Источник: https://blogs.msdn.microsoft.com/axs...s-of-interest/
Consider a scenario where you are running AX 2012 and your Dynamics AX databases are hosted on a Clustered SQL Server instance. I’ll discuss some concepts and points of interest below which are relevant when running AX 2012 RTM, R2 or R3. The screenshots are from a VM TEST environment with CONTOSO DEMO DATA that is... Read more
goshoom: New X++ features in AX 7 Blog bot DAX Blogs 0 19.02.2016 01:13
emeadaxsupport: AlwaysOn – Example AX TEST environment configuration concepts and points of interest Blog bot DAX Blogs 0 27.01.2016 16:11
emeadaxsupport: Writing Data Upgrade Scripts Part 1: Understanding the components of the process Blog bot DAX Blogs 0 10.02.2012 05:16
chrisfie: Project Server 2007 TechNet Webcasts recordings and decks Blog bot DAX Blogs 0 21.07.2009 10:05
Часовой пояс GMT +3, время: 06:38.
