Старый 24.09.2016, 10:14   #1
organicax: Warehouse location labels
Источник: https://organicax.com/2016/09/23/war...cation-labels/
If you need to print warehouse locations labels there is a basic list report that you can use. It’s a basic list that can print the warehouse, barcode for the location and check text. There isn’t much formatting on this and it is an SSRS report so if you need to do a lot of formatting to match the type of labels you need to use you might need to evaluate is it worth the effort to modify the SSRS report in AX or use a specialized label tool like Bartender or Nice Label for example as these would give more flexibility.
Here is a quick overview.
AX2012 R3 CU11.
Cheers
Lachlan
Filed under: Warehouse management
organicax: Warehouse mobile device text colors some additional notes on setup Blog bot DAX Blogs 0 25.03.2016 12:11
DynamicsAxSCM: Change license plate, split quantity, skip and override location during inbound put away Blog bot DAX Blogs 0 27.11.2015 16:11
DynamicsAxSCM: Migration of Microsoft Dynamics AX WMS to new R3 warehouse and transportation functionality Blog bot DAX Blogs 0 17.08.2015 20:19
DynamicsAxSCM: Monitor and analyse current and future warehouse space utilization with Dynamics AX 2012 R2 Blog bot DAX Blogs 1 13.12.2012 01:01
dynamicsaxtraining: Setup initial data (Vendor, Warehouse, Equipment) Blog bot DAX Blogs 0 07.12.2009 19:05
Часовой пояс GMT +3, время: 22:37.
