Старый 05.03.2012, 22:30   #1
INTRODUCTION
Electronic communication with the Dutch Tax administration is based on trusted connections using Digital Certificates. In 2011 an incident has occurred with Diginotar, one on the Certificate Authorities (CA), resulting in a situation that an infiltrator was able to create new certificates on his own for every random domain. This made the whole certificate-based environment unsecure and required facilities to make sure that trusted digital communication remains possible in the future.
The Dutch Tax administration evaluated the different existing communication channels and decided to phase out one of these channels: BAPI-PIN. It has also been decided to no longer use Diginotar certificates but to give KPN (Getronics) the role as the Certificate Service Provider (CSP) for the future.
SUBMITTING VAT AND ICP DECLARATIONS USING MICROSOFT DYNAMICS NAV
You can choose to submit VAT and or ICP to the Dutch Tax Authority by manually filling in a web form (www.belastingdienst.nl). There is a limit however for the ICP declaration. The website allows a maximum of 99 lines to be entered manually. An ICP Declaration report can be printed from Microsoft Dynamics NAV to use as a guideline.
Microsoft Dynamics NAV supports the BAPI channel electronic communication. Within the BAPI channel both PIN and PKI method are possible by Microsoft Dynamics NAV.
PIN is the public key method and mostly used within the Microsoft Dynamics NAV community. For this method you only need the certificates from the Tax authorities and CSP. To get these you have to fill in the fields on tab Certificates of the ‘Elec. Tax Declaration Setup’ page and get the certificates by the function ‘Get CA Tax Auth. Certificates’. The certificates for the PIN method can be acquired at no cost.
PKI is the private key method. This method uses user certificates for encrypting the message and providing a digital signature. For PKI 4 different types of certificates are needed:
  • certificate from the tax authority (same as for PIN method)
  • CSP certificate. This will be used to check the certificates (same as for PIN method).
  • user certificate to encrypt the message (E-certificate)
  • user certificate for digital signature (DS-certificate/Authentication certificate)
A company has to buy the user certificates. On the KPN site you will find all this information.
TIMELINE
With respect to PIN and PKI the following timeline has been set by the Tax authorities (latest communication in Feb 2012):
  • BAPI PIN: will be phased out by 1-1-2013 for all process flows (VAT, ICP, etc)
  • BAPI PKI: will remain. The certificates of Diginotar need to be replaced before 1-6-2012 by the certificates of the KPN. Until 1-6-2012 it will still be possible to use the Diginotar certificates. The tax authorities urge not to wait until the last day with changing certificates.
MICROSOFT DYNAMICS NAV AND BAPI PIN
In order to continue using PIN until 2013 you will need to change the certificate settings to KPN before June 2012.
To realize this, please change the following settings in the “Electr. Tax Declaration Setup” under the “Certificates” Fast TAB (production environment parameters). Make sure you have no ongoing declarations.
  • Directory LDAP server:
ldap.kpnbapi.managedpki.com:389
  • CA certificate search string:
CN=KPN Corporate Market Tax CA G2,O=KPN Corporate Market BV,C=NL
  • Tax Auth. Cert. Search string:
CN=Belastingdienst,OU=Servercertificaat E - zie CPS,L=Apeldoorn Joost van den Vondellaan 14 (0000),O=Belastingdienst (2000000002),C=NL
No need to change other settings. After that you can renew the certificate by using the function “Get CA Tax Auth. Certificates” and do your normal submissions again.
For testing purposes you can use the following test environment parameters (you should have a test account at Tax Authorities):
ldap.testkpnbapi.managedpki.com:389
CN=KPN Corporate Market Tax TEST CA G2,O=KPN Corporate Market BV,C=NL
CN=TEST Belastingdienst,OU=Servercertificaat E - zie CPS,L=Apeldoorn Joost van den Vondellaan 14 (0000),O=Belastingdienst (2000000002),C=NL
MICROSOFT DYNAMICS NAV AND BAPI PKI
If you are using the PKI method to submit the declarations, then you will need to ask for a (re)new(al) certificate at KPN. The Tax Authorities have already informed the users of PKI certificates on this process. Microsoft needs to investigate if Microsoft Dynamics NAV is able to work with KPN certificates under which conditions.
Tests for requesting KPN PKI certificates and submitting declarations are in process at the moment. You will be informed in a timely manner what changes are needed.
Источник: http://feedproxy.google.com/~r/Micro...ates-2012.aspx
Часовой пояс GMT +3, время: 18:59.
