I received a question from a customer, who is running multiple companies and often have multiple instances of NAV open with different companies. On the main page, they do have information about what company is the active:
![]() but when they have opened a number of Task Pages in the various instances of NAV, they cannot distinguish one from the other. Example: ![]() This image tells you the page and the Customer name – and you can easily identify the right page when Alt+TAB’ing between pages, but if you have multiple companies this doesn’t help you a lot. So what determines the caption? The fields used in the caption on a page is determined by: DataCaptionExpr on the page. This is an expression, which can use fields, functions etc. to build up a caption. If that isn’t defined, the client looks for DataCaptionFields on the page. This is a collection of fields, which are used to build the caption by adding them together with a character 183 (middle dot) between them. If that isn’t defined, the client looks for DataCaptionFields on the table, which basically is the same as DataCaptionFields on the page. In a standard NAV, there is no DataCaptionExpr nor DataCaptionFields defined on the Customer Card, but on the Customer table you find: ![]() In order to add the Company name behind the caption you will need to change the DataCaptionExpr on the Customer Card to f.ex. "No." + ' · ' + Name + ' ['+COMPANYNAME+']' which would cause the Customer Card to look like ![]() You can of course select to change the expression to whatever you like – or maybe create some function, which automagically returns a caption, only real flipside is that you need to modify the card pages, on which you need this functionality. In the end this is probably not a very large number. Enjoy Freddy Kristiansen PM Architect Microsoft Dynamics NAV Подробнее
