Ошибка при установке корпоративного портала ax2009, ошибка доступа
win2003x64, sql2008, ax2009sp1
При установке корпоративного портала на базе ax2009 происходит ошибка X++: UpgradeEnterprisePortalSite
. ( HRESULT: 0x80070005 (E_ACCESSDENIED))
System.UnauthorizedAccessException
Microsoft.SharePoint.SPGlobal.HandleUnauthorizedAccessException(UnauthorizedAccessException ex)
Microsoft.SharePoint.Library.SPRequest.OpenWeb(String bstrUrl, String& pbstrServerRelativeUrl, String& pbstrTitle, String& pbstrDescription, Guid& pguidID, String& pbstrRequestAccessEmail, UInt32& pwebVersion, Guid& pguidScopeId, UInt32& pnAuthorID, UInt32& pnLanguage, UInt32& pnLocale, UInt16& pnTimeZone, Boolean& bTime24, Int16& pnCollation, UInt32& pnCollationLCID, Int16& pnCalendarType, Int16& pnAdjustHijriDays, Int16& pnAltCalendarType, Boolean& pbShowWeeks, Int16& pnFirstWeekOfYear, UInt32& pnFirstDayOfWeek, Int16& pnWorkDays, Int16& pnWorkDayStartHour, Int16& pnWorkDayEndHour, Int16& pnMeetingCount, Int32& plFlags, Boolean& bConnectedToPortal, String& pbstrPortalUrl, String& pbstrPortalName, Int32& plWebTemplateId, Int16& pnProvisionConfig, String& pbstrDefaultTheme, String& pbstrDefaultThemeCSSUrl, String& pbstrAlternateCSSUrl, String& pbstrCustomizedCssFileList, String& pbstrCustomJSUrl, String& pbstrAlternateHeaderUrl, String& pbstrMasterUrl, String& pbstrCustomMasterUrl, String& pbstrSiteLogoUrl, String& pbstrSiteLogoDescription, Object& pvarUser, Boolean& pvarIsAuditor, UInt64& ppermMask, Boolean& bUserIsSiteAdmin, Boolean& bHasUniquePerm, Guid& pguidUserInfoListID, Guid& pguidUniqueNavParent, Int32& plSiteFlags, DateTime& pdtLastContentChange, DateTime& pdtLastSecurityChange, String& pbstrWelcomePage)
Microsoft.SharePoint.SPWeb.InitWeb()
Microsoft.SharePoint.SPWeb.get_WebTemplateId()
Microsoft.Dynamics.Framework.Deployment.Portal.EPSharepointAdmin.UpgradeEnterprisePortalSite(String siteUrl, String featureName)
Microsoft.Dynamics.Framework.Deployment.Portal.EPDeployment.UpgradeSitesToDAX50(String virtualServerUrl)
: . ( HRESULT: 0x80070005 (E_ACCESSDENIED))
И почему никто меня не любит? ![]() Да, я надоедливый |
| Теги |
| ax2009, sharepoint, корпоративный портал, ошибка, установка |
| Опции просмотра | |
