Старый 23.06.2008, 14:47   #1
http://wiki.dynamicsbook.com/index.php?tit..._Numbers_in_NAV
выдержка
Database versions for: 4.0
20 : Pre-release data formats (change in Session view for new Idle Time column; change in permission table to include new object types)
30 : [SP 2] Security release data formats (change in Session view, removing join to syslockinfo; change in chartable; creation of security objects)
40 : [4.1 SP 2] Release data formats (added locktimeout, locktimeoutperiod, hardrowlock and bufferedrows dbproperties)
50 : [4.2 Update 3] No actual database conversion was made
60 : [SP 3] Release data formats (alterable security option; fix for SIFT data corruption around Closing Dates; added securityoption dbproperty)
61 : Rebuilding SIFT triggers in order to correct the Sum problem
62 : Rebuilding SIFT triggers in order to correct the delete statement
63 : [SP 3 Update 8 Build 26565] Prevention of updating SIFT twice
Database versions for: 5.0
80 : Release data formats (added system tables for office integration and record links; change in table descriptions for clustered property)
81 : Rebuilding SIFT triggers in order to correct the Sum problem
82 : Rebuilding SIFT triggers in order to correct the delete statement
95 : [SP 1] Removed SIFT tables and triggers, creating Indexed Views instead
Database versions for: 6.0
120 : Pre-release data formats (incl. CTP1) (added several new system tables; extended record links system table)
130 : Pre-release data formats (incl. CTP2) (removed SIFT tables and triggers, creating Indexed Views instead)
140 : Pre-release data formats (removed Assembly and Relationship system tables; added enabledforservice dbproperty)
Подробнее... http://blogs.technet.com/alexef/archive/20...ionNumbers.aspx
Часовой пояс GMT +3, время: 05:56.
