Старый 04.04.2016, 16:11   #1
sashanazarov: Error executing code: The field with ID '0' does not exist in table 'SysExtensionSerializerExtensionMap'.
Источник: http://sashanazarov.blogspot.com/201...with-id-0.html
If you ever get "Error executing code: The field with ID '0' does not exist in table 'SysExtensionSerializerExtensionMap'." error in CIL, it may happen it is the table extension framework + the standard buf2buf function to blame.
Somehow, if you pass a Map instead of a table to buf2buf function, the following line fails:
_to.(fieldId) = _from.(fieldId);
However, if you replace this line with:
fieldName = fieldId2name(_from.TableId, fieldId);
_to.setFieldValue(fieldName, _from.getFieldValue(fieldName));
everything is fine both in X++ and in CIL.
P.S. I didn't dare to change the standard buf2buf method. Istead, I created another method and used it in the table extension framework logic, which failed because of the issue (\Data Dictionary\Maps\SysExtensionSerializerMap\Methods\copyExtensionTableData)
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 16 Blog bot Dynamics CRM: Blogs 0 23.01.2014 03:15
emeadaxsupport: The 'view details' feature will not work on an EDT field when the field has a relation defined in the 'table references' subnode. Blog bot DAX Blogs 0 26.01.2013 02:14
daxdilip: Error executing code: The field with id 0 does not exist in table Blog bot DAX Blogs 0 26.10.2011 02:17
daxline: The field with ID '0' does not exist in table - Cause and resolution. Blog bot DAX Blogs 0 30.08.2011 01:18
Часовой пояс GMT +3, время: 14:32.
