Старый 30.03.2016, 01:18   #1
organicax: Using the filter button in the Excel add-in.
Источник: http://organicax.com/2016/03/29/usin...-excel-add-in/
In a previous post we had a look at adding a new record into Dynamics AX. When you are working with data you can filter the records in Excel or use the filter option in the Add-in. This would be handy if you have a large around of customer records.
Here is a quick overview.
AX Build 7.0.1265.3015
Cheers
Lachlan
Filed under: Business intelligence
emeadaxsupport: Excel hangs while publishing/uploading data using the Excel Add-in for Dynamics AX Blog bot DAX Blogs 0 30.05.2015 04:24
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
atinkerersnotebook: Using Excel to Import Products & Services in Dynamics AX Blog bot DAX Blogs 0 19.07.2013 15:11
emeadaxsupport: How to copy a budget to a new budget in AX 2012 using Excel Add-in Blog bot DAX Blogs 0 27.11.2012 15:11
Часовой пояс GMT +3, время: 09:01.
