Старый 27.01.2016, 17:11   #1
atinkerersnotebook: The New Dynamics AX Tip #20: Adding additional fields to forms
Источник: http://atinkerersnotebook.com/2016/0...elds-to-forms/
The New Dynamics AX is a big change from the previous releases. The majority of the changes are around the new web based user interface, the new way that you navigate around in the application and also new sets of tools that have come along for the ride.
For those of you that are familiar with the older user interfaces then you may have to learn a couple of new tricks to get around the system like the pro that you are, and for new users of the New Dynamics AX environments then you will probably want as many tips on all the cool things that you are hidden away within the application so that you can quickly become a power user of the system.
I have scoured all of the resources that I have to compile the most useful tips and tricks for the New Dynamics AX and that will be useful to everyone, regardless of if you are a novice to Dynamics AX just trying to get around in the application, or have worked with the previous versions of the system, and are just want to learn the nuances of the new user interface.
Another personalization that you can perform is the adding of additional fields to the forms that may not already be on the form.
How to do it…
To do this, right-mouse-click on the form.
When the context menu item is displayed, click on the Personalize Grid option.
This will open up a personalization selector and you can then click on the Add a field link.
This will then open up a Add a Field dialog and all you need to do is check the additional fields that you want to show on the form.
After you have selected the fields, click on the Insert button.
When you return back to the form you will see that the fields have been added to the list page.
Want more?
If you liked this post and want to see more tips and tricks for the New Dynamics AX then I have compiled the 50 initial tips and tricks into a new guide for you all. If you want to get all of the tips and tricks in one place, then just follow the link: http://bit.ly/1mAzKf6
Also, if you are looking for more resources on Dynamics AX in general, then make sure you check out the Dynamics AX Companions site at www.dynamicsaxcompanions.com and also the Blind Squirrel Publishing site at www.blindsquirrelpublishing.com for more articles and books.
About the Author
Murray Fife is an Author of over 25 books on Microsoft Dynamics AX including the Bare Bones Configuration Guide series of over 15 books which step the user through the setup of initial Dynamics AX instance, then through the Financial modules and then through the configuration of the more specialized modules like production, service management, and project accounting. You can find all of his books on Amazon (www.amazon.com/author/murrayfife) and also even more on the BSP (www.blindsquirrelpublishing.com) site.
Murray is also the curator of the Dynamics AX Companions (www.dynamicsaxcompanions.com) site which he built from the ground up as a resource for all of the Dynamics AX community where you can find walkthroughs and blueprints that he created since first being introduced to the Dynamics AX product.
Throughout his 25+ years of experience in the software industry he has worked in many different roles during his career, including as a developer, an implementation consultant, a trainer and a demo guy within the partner channel which gives him a great understanding of the requirements for both customers and partner’s perspective.
For more information on Murray, here is his contact information:
Email:         mcf@blindsquirrelpublishing.com
Twitter:    @murrayfife
Facebook:    facebook.com/murraycfife
Google:        google.com/+murrayfife
LinkedIn:    linkedin.com/in/murrayfife
Blog:        atinkerersnotebook.com
Docs:        docs.com/mufife
Amazon:    amazon.com/author/murrayfife
atinkerersnotebook: The New Dynamics AX Tip #16: Responsive Zooming In And Out On Forms Blog bot DAX Blogs 0 19.01.2016 16:11
atinkerersnotebook: The New Dynamics AX Tip #10: Using the search feature to fund functions Blog bot DAX Blogs 0 08.01.2016 15:11
atinkerersnotebook: The New Dynamics AX Tip #8: Using the employee self-service workspace Blog bot DAX Blogs 0 06.01.2016 16:12
atinkerersnotebook: Self Service Reporting for Dynamics AX Users – Part 3: Adding Additional Fields to List Page Views Blog bot DAX Blogs 0 07.10.2015 18:11
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 16 Blog bot Dynamics CRM: Blogs 0 23.01.2014 03:15
Часовой пояс GMT +3, время: 21:12.
