Старый 15.06.2015, 18:11   #1
Dynamics AXBR: Preserving the MorphX VCS when a Backup / Restore is needed.
Источник: http://feedproxy.google.com/~r/daxbr/~3/wF45_T8XS0s/
Hello,
A very common situation is when developers need update their database with fresh data from test or production environments, but the problem begins when you use the MorphX VCS and need to keep this data. Below I show the shortest and fastest way that I’ve found to do that:
First, we need make a backup of VCS data, for that, connect at the SQL using the Microsoft SQL Server Management Studio, choose the database that you need to update with the fresh data and then run the commands:
1234567--Creating a temp database to use on our processCREATE DATABASE MyTempBackup --Backuping the dataSELECT * INTO MyTempBackup.dbo.SysVersionControlMorphXItemTable FROM SysVersionControlMorphXItemTableSELECT * INTO MyTempBackup.dbo.SysVersionControlMorphXLockTable FROM SysVersionControlMorphXLockTableSELECT * INTO MyTempBackup.dbo.SysVersionControlMorphXRevisionTable FROM SysVersionControlMorphXRevisionTable
Now you can restore the fresh data on DEV’s environment and then we can restore our backuped data.
123456789101112--Just to ensure that there is no trash on tables, you can skip this stepTRUNCATE TABLE SysVersionControlMorphXItemTableTRUNCATE TABLE SysVersionControlMorphXLockTableTRUNCATE TABLE SysVersionControlMorphXRevisionTable --Restoring the dataINSERT INTO SysVersionControlMorphXItemTable SELECT * FROM MyTempBackup.dbo.SysVersionControlMorphXItemTableINSERT INTO SysVersionControlMorphXLockTable SELECT * FROM MyTempBackup.dbo.SysVersionControlMorphXLockTableINSERT INTO SysVersionControlMorphXRevisionTable SELECT * FROM MyTempBackup.dbo.SysVersionControlMorphXRevisionTable --Removing the temp databaseDROP DATABASE MyTempBackup
See ya,
Pichler
CRM DE LA CREME! CRM 4.0 Disaster Recovery Blog bot Dynamics CRM: Blogs 2 26.02.2016 08:23
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 17 Blog bot Dynamics CRM: Blogs 0 10.05.2014 06:30
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 16 Blog bot Dynamics CRM: Blogs 0 23.01.2014 03:15
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 10 Blog bot Dynamics CRM: Blogs 0 17.08.2012 03:27
Часовой пояс GMT +3, время: 23:29.
