Старый 04.07.2014, 08:11   #1
mscrmblog: Setting the List in ReadOnly mode to disable most buttons on the ribbon
Источник: http://mscrmblog.net/2014/07/04/sett...on-the-ribbon/
Another requirement from the customer is at the Archive Centre no one should be able to upload/delete any documents through the UI.
There is a property that can be set on the list to disable the Ribbon bar and commands.
public override void FeatureActivated(SPFeatureReceiverProperties properties) { var web = properties.Feature.Parent as SPWeb; web.AllowUnsafeUpdates = true; var documentList = web.Lists["Archived Documents"]; documentList.ReadOnlyUI = true; documentList.Update(); web.Update(); }
mscrmblog: Disable Automatic Document Property Promotion on a List Blog bot Dynamics CRM: Blogs 0 25.06.2014 05:22
Gareth Tucker: Dynamically Disable Ribbon Buttons in Dynamics CRM Blog bot Dynamics CRM: Blogs 0 26.11.2013 10:11
Gareth Tucker: Adding Record Creation Buttons to the CRM 2011 Ribbon Blog bot Dynamics CRM: Blogs 0 12.01.2012 15:11
Gareth Tucker: Editing Ribbon Buttons in CRM 2011 Blog bot Dynamics CRM: Blogs 0 24.08.2011 09:11
mscrmblog: Customize Marketing List (List Member View) Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
Часовой пояс GMT +3, время: 22:45.
