Старый 11.06.2014, 23:12   #1
atinkerersnotebook: Declutter Your System By Turning Off License Features You Don’t Use
Источник: http://atinkerersnotebook.com/2014/0...-you-dont-use/
Originally posted on Dynamics AX Tip Of The Day:
Dynamics AX is chock full of useful features, but you probably don’t need to use it all right away, and in some cases even through other people will need a particular feature you may never consider using it. Rather than having everything enabled within the system, you can use the license configuration tool to deactivate is so that it’s not showing up on the forms, and the menus. Later on if you find that you want to use the feature then you can always just turn it back on again.
Don’t be an extreme hoarder when it comes to ERP features.
View original 317 more words
atinkerersnotebook: Using Vendor Requests to Manage On-boarding New Vendors Blog bot DAX Blogs 1 22.10.2013 02:24
atinkerersnotebook: Creating Your Own Document Management System With SharePoint Blog bot DAX Blogs 0 02.10.2013 21:12
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
Удаленная работа с CRM и расширеный поиск ASheff Dynamics CRM: Разработка 64 04.06.2010 17:44
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Часовой пояс GMT +3, время: 18:15.
