Старый 30.05.2014, 15:11   #1
atinkerersnotebook: Convert Any Record Into A Template
Источник: http://atinkerersnotebook.com/2014/0...to-a-template/
Originally posted on Dynamics AX Tip Of The Day:
You may be familiar with the template capabilities that are available within the Released Products, but that isn’t the only place that you can create templates. You can turn any record within Dynamics AX into a public or personal template that you can use to pre-populate fields saving you setup time, and also ensuring that all of the miscellaneous fields are configures just how you like them.
It’s like having your own cookie cutter creator.
View original 184 more words
atinkerersnotebook: Using Vendor Requests to Manage On-boarding New Vendors Blog bot DAX Blogs 1 22.10.2013 02:24
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
atinkerersnotebook: Configuring Lean Manufacturing in Dynamics AX 2012 Blog bot DAX Blogs 1 12.08.2013 00:15
atinkerersnotebook: Using Excel to Import Products & Services in Dynamics AX Blog bot DAX Blogs 0 19.07.2013 15:11
Часовой пояс GMT +3, время: 20:57.
