Axilicious:Release Management – Customize timouts on default tools / actions
Источник: http://www.ksaelen.be/wordpresses/dy...tools-actions/
============== In Release Management for Visual Studio 2013, you can customize your tools and actions to work with. The last few days I was creating a Release template for use with Dynamics AX 2012. One of the actions early in the template is backing up the database. ( Of course you need to backup first ![]() So I decided to go back to the Restore SQL Database action and adjust the timeout setting. But hey, you are unable to do that on the default tool! There is a parameter to setup default timeouts, but this only applies when creating new actions. So that doesn’t help a lot. So for me, the most convenient and simple solution was to copy the tool that is available out of the box and create a new one from it. Then you do have the ability to set the timeout. Источник: http://www.ksaelen.be/wordpresses/dy...tools-actions/
Опции просмотра | |
