Старый 05.09.2013, 01:12   #1
Axilicious:AX2012 R2 Enterprise portal installation issues – Part 1
Источник: http://www.ksaelen.be/wordpresses/dy...issues-part-1/
The last few days I have been playing around with the Enterprise Portal. I needed to setup a High Available portal and there were soms discoveries along the road.
Though I’m planning on writing some other posts on the general architecture used when installing the Enterprise Portal in a HA environment and the possible installation issues you might have, I wanted to discuss one of the smaller issues encountered.
When opening the Enterprise Portal site, you can run into the following error:
c:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\14\TEMPLATE\LAYOUTS\ep\EPSecurityControl.ascx.cs(13): error CS0234: The type or namespace name ‘AX’ does not exist in the namespace ‘Microsoft.Dynamics’ (are you missing an assembly reference?)
You can solve this by running the Ax installer for EP installation on all of the machines in the farm. When installing, uncheck all of the checkboxes to only install the binaries.
emeadaxsupport: Enterprise Portal in Microsoft Dynamics AX 2012 R2 now supports SharePoint 2013 Blog bot DAX Blogs 0 19.04.2013 20:13
emeadaxsupport: Microsoft Dynamics AX 2009 Enterprise Portal installation error Blog bot DAX Blogs 0 22.09.2011 20:11
daxdilip: How to Install Dynamics AX2012 Enterprise Portal - Part 2 Blog bot DAX Blogs 0 21.08.2011 22:13
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
JOPX: Integrating MOSS 2007 and Dynamics AX Part II - installing and configuring Dynamics AX Enterprise Portal Blog bot DAX Blogs 0 02.03.2008 06:42
Часовой пояс GMT +3, время: 15:52.
