Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 22.10.2013, 10:28   #1
Anitha Roy is offline
Anitha Roy
Post Whiling Compiling suddenly dialogbox is appearing as server is unavailable.check your configuration and network setting
Hi All,
Need ur help...Plz help me out...
Due to some reasons Our AOS crashed and we uninstalled the ax n DB and re-install it again..After importing the backup(Our Model) and tried to compile and synchornize the DB it..suddenly dialogbox is appearing as server is unavailable.check your configuration and network settings....Plz Help me out...
Старый 22.10.2013, 10:34   #2
user_ax is offline
user_ax
Аватар для user_ax
599 / 39 (3) +++
After re-install you done through the server setup utility AOSConfig(don't remember the exact title) ?
Старый 22.10.2013, 12:57   #3
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Сообщение от Anitha Roy Посмотреть сообщение
Such a dialog box usually means that your AOS has crashed (again?). So the problem is that an AOS crashes during the global compilation, right? What kernel version do you use? Did you try to compile the standard application first and import your modifications after that? Did you try to run the global compilation on the AOS host to avoid network connectivity-related issues?
Axilicious:Running AX2012 R2 locally on Windows 2012 Server booted directly from VHD Blog bot DAX Blogs 0 16.04.2013 08:13
chrisfie: Project Server 2007 TechNet Webcasts recordings and decks Blog bot DAX Blogs 0 21.07.2009 10:05
Solutions Monkey: Setting up EP in NLB Cluster Blog bot DAX Blogs 0 18.10.2008 02:08
Часовой пояс GMT +3, время: 07:14.
