Старый 14.06.2013, 13:11   #1
palleagermark: The enum that is specified in the input XML file does not exist in Microsoft Dynamics AX
Источник: http://www.agermark.com/2013/06/the-...input-xml.html
This is an error you might experience while trying to generate proxies for EP. This can be caused by having a table field setup with an enum that does not exist.
System enums, i.e. enums not in AOT / Data Dictionary / Enums, seems to be falling in the category if enums that "doesn't exists".
You can read a bit more about the issue here.
The error message it self doesn't reveal much information, so the fastest way to find the culprit seems to be to run a Best Practice Check for all your tables. The Best Practice Check will report the issue.
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 13 Blog bot Dynamics CRM: Blogs 0 27.03.2013 22:12
dynamicsaxbi: Better together: Microsoft Dynamics AX 2012 R2 and SQL Server Power View Blog bot DAX Blogs 0 12.12.2012 13:11
Microsoft Dynamics CRM Team Blog: The Microsoft Dynamics CRM Swiss Army Knife Blog bot Dynamics CRM: Blogs 1 19.04.2012 08:20
semanticax: Dynamics AX 2009 Installation - Application Blog bot DAX Blogs 0 22.12.2010 08:11
Developer for Microsoft Dynamics AX Certification Roadmap Blog bot DAX Blogs 1 13.05.2009 16:17
Часовой пояс GMT +3, время: 15:40.
