sashanazarov: Marking from code: part 2
Источник: http://sashanazarov.blogspot.com/201...de-part-2.html
============== In this post, I provided a code sample that manipulated InventMarking form from code to complete an ad-hoc task. Today I had to implement marking from X++ code again, but this time it should have been run on the server side on a daily basis, so I did have to use \Data Dictionary\Tables\TmpInventTransMark\Methods\updateTmpMark method instead of the form. As code samples I found in the Internet were outdated, I decided to post here code that did compile on my box (DAX 2012 CU3): static void testXppMarking(Args _args) { InventTrans issueInventTrans; TmpInventTransMark tmpInventTransMask; Map mapMarkNow; container con; real qty; Map mapTmp; MapEnumerator mapEnumerator; InventTransOriginId issueInventTransOriginId = InventTransOrigin::findByInventTransId('Issue lot ID').RecId; InventTransOriginId receiptInventTransOriginId = InventTransOrigin::findByInventTransId('Receipt lot ID').RecId; InventQty qtyToMark = 11; ttsBegin; issueInventTrans = InventTrans::findByInventTransOrigin( issueInventTransOriginId); [con, qty] = TmpInventTransMark::packTmpMark( InventTransOrigin::find(issueInventTransOriginId), issueInventTrans.inventDim(), issueInventTrans.Qty); mapTmp = Map::create(con); mapEnumerator = mapTmp.getEnumerator(); while (mapEnumerator.moveNext()) { tmpInventTransMask = mapEnumerator.currentValue(); if (tmpInventTransMask.InventTransOrigin == receiptInventTransOriginId) { tmpInventTransMask.QtyMarkNow = qtyToMark; tmpInventTransMask.QtyRemain -= tmpInventTransMask.QtyMarkNow; mapMarkNow = new Map(Types::Int64, Types::Record); mapMarkNow.insert(tmpInventTransMask.RecId, tmpInventTransMask); TmpInventTransMark::updateTmpMark( issueInventTransOriginId, issueInventTrans.inventDim(), -qtyToMark, mapMarkNow.pack()); break; } } ttsCommit; } Источник: http://sashanazarov.blogspot.com/201...de-part-2.html
За это сообщение автора поблагодарили: Pandasama (1). |
Опции просмотра | |
