Старый 14.11.2012, 14:11   #1
Malaysia: Building a selected/available list
Источник: http://axmas.blogspot.com/2012/11/bu...able-list.html
1. In the AOT, create a new table named InventBuyerGroupList. Do not change any of
the properties as this table is for demonstration only.
2. Add a new field to the table with the following properties (click on Yes if asked to add
a new relation to the table):
Property Value
Type String
Name GroupId
ExtendedDataType ItemBuyerGroupId
3. Add another field to the table with the following properties:
Property Value
Type String
Name CustAccount
ExtendedDataType CustAccount
4. In the AOT, open the InventBuyerGroup form and change the design properties
as follows:
Property Value
Style Auto
5. Add a new Tab control with the following properties, to the bottom of the design:
Property Value
Width Column width
Height Column height
6. Add a new TabPage control with the following properties to the newly created tab:
Property Value
Name BuyerGroups
Caption Buyer groups
7. Add another TabPage control with the following properties to the newly created tab:
Property Value
Name Customers
Caption Customers
8. Move the existing Grid control to the first tab page and hide the existing Body group
by setting the property:
Property Value
Visible No
9. The form should look similar to the following screenshot:
10. Add the following line to the form's class declaration:
SysListPanelRelationTable sysListPanel;
11. Override the form's init() method with the following code:
public void init()
container columns;
#ResAppl
columns = [fieldNum(CustTable, AccountNum)];
sysListPanel = SysListPanelRelationTable::newForm(element, element.controlId(
formControlStr(InventBuyerGroup,Customers)), "Selected", "Available", #ImageCustomer,
tableNum(InventBuyerGroupList), fieldNum(InventBuyerGroupList,CustAccount),
fieldNum(InventBuyerGroupList,GroupId), tableNum(CustTable),
fieldNum(CustTable,AccountNum), columns);
super();
sysListPanel.init();
12. Override the pageActivated() method on the newly created Customers tab page
public void pageActivated()
sysListPanel.parmRelationRangeValue(InventBuyerGroup.Group);
sysListPanel.parmRelationRangeRecId(InventBuyerGroup.RecId);
sysListPanel.fill();
super();
13. In order to test the list, open Inventory and warehouse management | Setup |
Inventory | Buyer groups, select any group, go to the Customers tab page and use
the buttons provided to move records from one side to the other. You could also do a
double-click or drag-and-drop with your mouse:
Malaysia: List Blog bot DAX Blogs 0 29.10.2012 19:11
Microsoft Dynamics CRM Team Blog: Marketing with Dynamic List Blog bot Dynamics CRM: Blogs 0 09.11.2010 19:05
CRM Programmer: On form load set some selected value for related entity pick-list Blog bot Dynamics CRM: Blogs 1 04.12.2009 09:23
Kashperuk Ivan: List panels in Dynaics AX - a short description of SysListPanel class Blog bot DAX Blogs 1 21.10.2007 22:51
Часовой пояс GMT +3, время: 11:25.
