ax-erp: How to traverse a directory in Axapta
Источник: http://microsoft-dynamics-ax-erp.blo...in-axapta.html
============== This example list all files in a directory including sub-directories. Handy when you need to do something with a number of files stored in a structure of folders. Here we lists all the text files it can find, you only need to alter the FO_ProcessFile() method for your needs. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 static void FO_ListTreeExample(Args _args) { void FO_ProcessFile(FilePath _path, FileName _name) { ; info( strfmt(" %1 / %2 ", _path, _name) ); } void FO_ProcessFolder(FilePath _path, FileName _mask) #WinApi { FileName fileName; container fileInfo; int fileHandle, attrs; ; // traverse all sub-directories fileInfo = WinApi::findFirstFile(_path + "\\*.*"); fileHandle = conpeek(fileInfo,1); fileName = conpeek(fileInfo,2); while(fileName != '') { if(fileName != '..' && fileName != '.') { attrs = WinApi::getFileAttributes( _path + "\\"+fileName); if(attrs & #FILE_ATTRIBUTE_DIRECTORY) FO_ProcessFolder(_path+'\\'+fileName, _mask); } fileName = WinApi::findNextFile(fileHandle); } // traverse all files on this level fileInfo = WinApi::findFirstFile(_path+"\\"+_mask); fileHandle = conpeek(fileInfo,1); fileName = conpeek(fileInfo,2); while(fileName != '') { if(fileName != '..' && fileName != '.') { attrs = WinApi::getFileAttributes( _path + "\\"+fileName); if( !(attrs & #FILE_ATTRIBUTE_DIRECTORY) ) FO_ProcessFile(_path, fileName); } fileName = WinApi::findNextFile(fileHandle); } }; FO_ProcessFolder("c:\\Temp", "*.txt"); } Источник: http://microsoft-dynamics-ax-erp.blo...in-axapta.html
