axaptacorner: Important function in x++ for AX 2009 and AX 2012
Источник: http://axaptacorner.blogspot.com/201...-2009-and.html
============== <div dir="ltr" style="text-align: left;" trbidi="on"> Important function in X++ Sub String in X++ static void subStr(Args _args) { str s; real r; ; r = strLen("jitendraknit@gmail.com"); s = subStr("jitendraknit@gmail.com",12, 2); print(strFmt("s=%1 and r=%2",s,r)); pause; } String Comparison in X++ static void strCmp(Args _args) { int i=2; str s1,s2; ; s1="string 1"; //s2="string 1"; s2="string 2"; i = strCmp(s1,s2); if (0 == i) { print "s1 and s2 are the same"; } else { print "s1 and s2 are different"; } pause; } String Deletion in X++ { str s; ; s = strDel("Jitendrakumar", 5, 2); print s; pause;//for cut the string size first give from where it will cut thn give till thn it will cut } Find characters in string in X++ { int i; ; i = strfind("jitendrakumar", "jit", 0, 3); if (1 == i) { print "Characters are found in string"; } else { print "Characters are NOT found in string"; } pause; } Strfmt()in X++ { str s1 ="testing"; int s2 = 2; real s3 =4.56; str s; ; s = strfmt("string =%1,Integer = %2, Real = %3, ", s1,s2,s3); print s; pause; } Length of string in X++ static void strLen(Args _args) { int i; ; i = strLen("jitendra"); print(strFmt("i=%1",i)); pause; } Convert string in lower case in X++ static void strLwr(Args _args) { str l; ; l = strLwr("JITENDRA"); print(strFmt("l=%1",l)); pause; } Convert string in upper case in X++ { str u; ; u= strUpr("jitendra"); print(strFmt("u=%1",u)); pause; } Repetition of string in X++ static void strRep(Args _args) { str r; ; r = strRep("xyz ", 5); print(strFmt("r=%1",r)); pause; } Convert date into string in x++ static void systemDateGet(Args _args) { date d; str d1,d2,d3 ; ; d = systemdateget(); d1 = date2str(d,123,2,-1,2,-1,4); d2 = date2str(d,231,2,-1,2,-1,2); d3 = date2str(d,321,2,-1,2,-1,4); print(strFmt("dates are %1,%2,%3,%4",d,d1,d2,d3)); pause; } Truncate Real value in X++ static void trunc(Args _args) { real t; ; t = trunc(4.6789); print strfmt("t = %1", t); pause; } Creation of Dialog in X++ { Dialog dialog; DialogGroup dialogGroup; DialogField dialogField; ; dialog = new Dialog("Test Dialog"); dialogGroup = dialog.addGroup("Customer Details"); dialogField = dialog.addField(extendedTypeStr(Custaccount),"Account Number"); dialog.run(); } Create box for prompt in X++ { if(box::yesNo("Are u sure to close this form",dialogbutton::No,"Box Title")==dialogbutton::yes) { print("Closing......."); pause; } else { print("Not closing......"); pause; } } Container Operation in X++ // conLen() for the size of the container // conPeek() to get contents of container item // conNull() to Assign null value static void conpeek(Args _args) { container c; int i; ; c=conNull(); c =["item1", "item2","jit"]; c= conIns(c,2,"test"); <div class="MsoNormal" style="line-height: normal; margin: 0in 0in 0pt; mso-layout-grid-align: none;"><span style="font-family: Consolas; font-size: 8pt;"><span style="color: orange;"> for (i = 1 ; i
MCT
Очередной кумар начал изучать аксапту и решил поделиться значимыми для него событиями.
Axapta book for developer |
Британский учённый
Старался человек, вон какая у него подсветка кода, обзавидуешься
Людям физического труда для восстановления своих сил нужен 7-8 часовой ночной сон. Людям умственного труда нужно спать часов 9-10. Ну а программистов будить нельзя вообще. |
Опции просмотра | |
