Старый 25.07.2012, 21:11   #1
sashanazarov: Regex looking for return calls within ttsbegin/ttscommit
Источник: http://sashanazarov.blogspot.com/201...ls-within.html
Return calls should never appear within a ttsbegin/ttscommit pair. If they do, the application may eventually complain that
I have recently had to look for such an issue in a third-party code, and this is the job I used to looks for suspecious "returns", which did find one. Please note, that with the current regex pattern, there may be false positives, but in my case it would take more time to write a perfect pattern, than to manually look through those false positives:
static void checkSourceForReturnsInTTS(Args _args)
TreeNode treeNode;
TreeNode sourceTreeNode;
TreeNodeIterator it;
ProjectNode projectNode;
TreeNodeTraverserSource traverser;
Source source;
System.Text.RegularExpressions.MatchCollection mcReturnsInTTS;
System.Text.RegularExpressions.Match mReturn;
int matchCount;
int matchIdx;
str pattern = 'ttsbegin.*[^a-z0-9_]return[^a-z0-9_].*ttscommit';
str matchString;
projectNode = SysTreeNode::getPrivateProject().AOTfindChild("MyProject");
treeNode = projectNode.loadForInspection();
traverser = new TreeNodeTraverserSource(treeNode);
while (traverser.next())
sourceTreeNode = traverser.currentNode();
source = sourceTreeNode.AOTgetSource();
source = System.Text.RegularExpressions.Regex::Replace(
source,
System.Text.RegularExpressions.RegexOptions::Singleline);
source,
'[/]{2,}.*\n',
mcReturnsInTTS = System.Text.RegularExpressions.Regex::Matches(
strLwr(source),
pattern,
matchCount = CLRInterop::getAnyTypeForObject(mcReturnsInTTS.get_Count());
if (matchCount > 0)
info(sourceTreeNode.treeNodePath());
Падает стандартный импорт с ошибкой "Вызов ttscommit без вызова ttsbegin" skof DAX: Администрирование 6 19.01.2012 17:12
dynamics-ax-dev: CLR Errors & ttsbegin/ttscommit Blocks Blog bot DAX Blogs 0 02.11.2010 18:05
ttsbegin ttscommit and changecompany() Volodymyr DAX: Программирование 9 29.08.2008 15:36
вопрос по ttsbegin-ttscommit McCoy DAX: Программирование 3 07.02.2006 21:22
Вложенные транзакции ttsbegin\ttscommit dn DAX: Программирование 9 19.01.2004 17:07
Часовой пояс GMT +3, время: 01:39.
