Старый 25.07.2012, 03:28   #1
emeadaxsupport: Retail 2012: Store Connect Pack Viewer “Cannot find deserializer” error
Источник: http://blogs.msdn.com/b/axsupport/ar...zer-error.aspx
If you rely on the Retail Store Connect Pack Viewer to debug your data path between headquarters and your stores you may run into this error:
“Cannot find deserializer for request header type:  Microsoft.Dynamics.Retail.StoreConnect.Request.Base.SCTargetRequestHeader”
This is due to a problem with how the packet viewer determines if a packet is a “source” packet or a “target” packet.  In previous versions, this distinction was based solely on the filename:  “SERVER8HQ-114-I.tmp” vs. “SERVER8HQ-114-R.tmp”.  However, there are certain scenarios in 2012 where an “I” packet should be evaluated as an “R” packet.
This issue will be fixed in a future release, but in the meantime there is a very simple workaround you can do to get past the error:  rename your file in your temp directory.  In my case I renamed my file to “SERVER8HQ-114-R.tmp” and the Pack Viewer was able to extract the data to a subfolder:
This subfolder will have XML representations of the contents which you can then load using any XML viewer.
axretail
emeadaxsupport: AX2012 Retail error 32769 in Store connect while running P-job Blog bot DAX Blogs 0 10.06.2012 14:12
emeadaxsupport: AX for Retail: Bulk insert error in Store connect when running P job (error 32769) Blog bot DAX Blogs 0 01.06.2012 13:11
axinthefield: Dynamics Ax 2009 Retail Error Messages & Possible resolutions Blog bot DAX Blogs 0 23.05.2012 11:11
emeadaxsupport: AX for Retail 2012: Store Connect missing mfc100u.dll error Blog bot DAX Blogs 0 25.04.2012 03:18
Часовой пояс GMT +3, время: 16:36.
