emeadaxsupport: Microsoft Dynamics AX 2012 Reporting: How to run reports that executes longer than 10 minutes
Источник: http://blogs.msdn.com/b/axsupport/ar...0-minutes.aspx
============== Sometime ago we run into problem when reports that executes longer than 10 minutes are running into timeout error. To overcome this problem: - For reports printed in batch job you need to install kernel hotfix KB 2642168 - the KB article is still not published on Partner source but you should be able to get hotfix through Microsoft Dynamics AX Support team - For reports printed on screen. You need to:
Опции просмотра | |
