Старый 13.09.2011, 10:11   #1
Gareth Tucker: Working with Display Rules in CRM 2011–Ribbon Customisation
Источник: http://gtcrm.wordpress.com/2011/09/1...customisation/
In this post I provide a quick guide on how to apply Display Rules to your custom ribbon buttons in Microsoft CRM 2011.
Firstly, here’s a quick run through on how to apply a Display Rule.
I have added a custom button to the Campaign form’s ribbon, as per below:
To add a display rule to limit when the button should appear I need to do 2 things:
1. Define the Display Rule
2. Assign the Display Rule to the button
To define the Display Rule we need to add the following to our customization.xml file:
This can be read as:
“I want to define a new display rule called "GT.campaign.Form.Star.FormStateNotCreate.DisplayRule".  The rule is the button should only show if the form is not the Create form”.
And then to assign this rule to our button we simply reference the above ID in the Command Definition of our button:
Here’s a few more common Display Rule examples:
Display only on Create form:
Display only on Update or Create form:
Do NOT display when Offline:
Gareth Tucker: Installing the Customer Care Accelerator (CCA) for CRM 2011 Blog bot Dynamics CRM: Blogs 3 23.12.2011 09:16
Gareth Tucker: Adding a new Button Group to the CRM Ribbon Blog bot Dynamics CRM: Blogs 0 24.08.2011 16:11
Gareth Tucker: Editing Ribbon Buttons in CRM 2011 Blog bot Dynamics CRM: Blogs 0 24.08.2011 09:11
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM 2011 ~ Online Test Drive Guide Blog bot Dynamics CRM: Blogs 0 05.08.2011 20:13
Gareth Tucker: Getting Started with CRM 2011 Online Fetch XML Reporting Blog bot Dynamics CRM: Blogs 0 19.05.2011 23:13
Часовой пояс GMT +3, время: 11:51.
