Старый 10.06.2011, 11:11   #1
Preston.Larimer: Sales order creation at the most basic with ax Classes
Источник: http://palarimer.greenlight2go.com/2...asic-with.html
Programmatic creation of a sales order can range from complex to easy, this is by far the Easy example making use of the axSalesTable and axSalesLine classes you dont get much easier than this. The example should be a good starting point the ID’s used are part of the standard Demo data.
static void CreateSalesOrder_Job(Args _args)
    axSalesTable axSalesTable;
    salesID salesID;
    axSalesline axSalesLine;
    ttsBegin;
    axSalesTable = new axSalesTable();
    axSalesTable.parmCustAccount('1101');
    axSalesTable.save();
    salesID = axSalestable.salesTable().SalesId;
    info(salesID);
    axSalesline = new axSalesLine();
    axSalesLine.parmSalesId(salesID);
    axSalesline.parmItemId('7009');
    axSalesLine.parmSalesQty(10);
    axSalesLine.save();
    //Line with dimensions
    axSalesline.parmItemId('1001');
    axSalesLine.parmSalesQty(1);
    axSalesLine.axInventDim().parmConfigId('HD');
    axSalesLine.axInventDim().parmInventSizeId('42');
    axSalesLine.axInventDim().parmInventColorId('02');
    axSalesLine.save();
    ttsCommit;
Последний раз редактировалось Poleax; 10.06.2011 в 13:25. Причина: оформление
Dynamics AX Sustained Engineering: POS Transaction with Sales Order that nets to $0.00 posting failure in statement Blog bot DAX Blogs 0 06.01.2011 20:16
palleagermark: Annoying bug in AX 2009 Intercompany Sales Order Blog bot DAX Blogs 0 21.01.2010 11:05
DynamicsAxSCM: Changes in Sales and Transfer Order Picking from Microsoft Dynamics AX 4.0 to Dynamics AX 2009 Blog bot DAX Blogs 0 18.05.2009 02:05
Передача функции в качестве параметра lemchey_white DAX: Программирование 20 21.01.2008 22:51
Часовой пояс GMT +3, время: 12:51.
