Старый 09.06.2011, 03:27   #1
dax-lessons: On dialogs – SysLookupMultiSelectCtrl in Dynamics AX 6.0
Источник: http://dynamicsaxgyan.wordpress.com/...namics-ax-6-0/
This post is in continuation of my old post which helped to use SysLookUpMultiSelectCtrl class on Forms.
The below class will help you to implement the same in the dialogs [Used Runbase framework]. Please note I have used the same query [CustTableLookUp] which I used in my last post.
Please follow the class and its methods as shown below.
public class SR_LookupMultiSelectDialog extends RunBase
DialogRunbase dialog;
DialogGroup dialogGrp;
FormBuildStringControl fbsCtrlMultiSelect1;
FormStringControl fsCtrlMultiSelect1;
container returnIds1;
SysLookupMultiSelectCtrl msCtrl1;
__________________________________________________
public ClassDescription caption()
return Multiple select lookup on ;
// Generate dialog
public Object dialog()
FormBuildControl setupGroupControl;
dialog = super();
dialog.alwaysOnTop(true);
dialog.windowType(FormWindowType::Standard);
dialogGrp = dialog.addGroup(Group);
setupGroupControl = dialog.formBuildDesign().control(dialogGrp.formBuildGroup().id());
// Control with the MULTI-SELECT
fbsCtrlMultiSelect1 = setupGroupControl.addControl(FormControlType::String, identifierstr(ctrlRoles1));
fbsCtrlMultiSelect1.label(Select multiple );
dialog.allowUpdateOnSelectCtrl(true);
this.dialogSelectCtrl();
return dialog;
public void dialogPostRun(DialogRunbase _dialog)
FormRun formRun;
super(dialog);
formRun = _dialog.dialogForm().formRun();
if (formRun)
fsCtrlMultiSelect1 = formRun.design().control(fbsCtrlMultiSelect1.id());
msCtrl1 = SysLookupMultiSelectCtrl::construct(formRun, fsCtrlMultiSelect1, querystr(CustTableLookUp));
// Get input values
public boolean getFromDialog()
#Characters
// Return Ids from the 1st mutli-select control
if (msCtrl1)
returnIds1 = msCtrl1.get();
info(Control 1   + con2StrUnlimited(returnIds1,#SEMICOLON));
return true;
static void main(Args _args)
SR_LookupMultiSelectDialog SR_LookupMultiSelectDialog = new SR_LookupMultiSelectDialog();
if (SR_LookupMultiSelectDialog.prompt())
SR_LookupMultiSelectDialog.run();
Below is the dialog [Screen shot for reference ] which will allow to select multiple values from the lookup
Please refer to Tutorial_LookUpMultiSelectDialog for more detailed example.
Happy Dax 6ng
Sreenath
Последний раз редактировалось Poleax; 09.06.2011 в 10:41. Причина: оформление
dax-lessons: SysLookupMultiSelectCtrl in Dynamics AX 6.0 [AX 2012, X++] Blog bot DAX Blogs 0 08.06.2011 21:11
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
dax-lessons: Password style Dialogs and validate the password in Active Directory [Dynamics AX, X++] Blog bot DAX Blogs 0 07.03.2011 18:11
Часовой пояс GMT +3, время: 23:48.
