Старый 14.05.2011, 05:29   #1
axdaily: Debugging managed code in AX 2012
Источник: http://axdaily.blogspot.com/2011/05/...n-ax-2012.html
Since a lot of X++ code is now executed in CLR there should be a possibility to debug it. The standard AX debugger cannot help here since it is capable of debugging interpreted code only. However, Visual Studio 2010 can do the job.
There are few steps needed to be able to debug managed X++ execution using VS:
  1. Breakpoints should be enabled on server (in AOS configuration).
  2. Visual Studio should be started with elevated permissions (run as administrator).
  3. Visual Studio should be attached to Ax32Serv.exe process (AOS process).
After that you can locate the source code and place the breakpoint. This can be done either using Application Explorer, or by opening .xpp source file directly from the [AX server path]\bin\XppIL\Source folder. Each method of each class or table has a separate .xpp file that is named [ClassName].[MethodName].xpp.
And that’s it. Now the debugging will happen is visual studio. Call stack, watches, etc. are also available.
ax2012, debugger, отладчик
axdaily: Models in AX 2012 Blog bot DAX Blogs 0 28.04.2011 04:27
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
emeadaxsupport: Debugging non-interactive X++ code in Dynamics AX 2009 when running on Windows Server 2008 Blog bot DAX Blogs 0 23.09.2009 13:05
Часовой пояс GMT +3, время: 15:02.
