Старый 09.05.2011, 18:08   #1
The following error may be encountered processing an XML document in the receive pipeline when using Commerce Gateway with Biztalk 2010 and Visual Studio 2010:
There was a failure executing the receive pipeline: "Microsoft.BizTalk.DefaultPipelines.XMLReceive, Microsoft.BizTalk.DefaultPipelines, Version=3.0.1.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" Source: "XML disassembler" Receive Port: "Navision_to_CommerceGateway" URI: "CG://Navision_to_CommerceGateway" Reason: The document specification <Assembly Name> from assembly <Assembly Name, Version=1.0.0.0, Culture=neutral, PublicKeyToken=Token ID> failed to load. Verify the schema for this document specification is deployed and is in the Global Assembly Cache.
In this scenario, Commerce Gateway Service hosts a BizTalk isolated host. The receive pipeline is executed within the context of this service. BizTalk Server 2010 by default deploys and looks for assemblies in the .Net Framework 4.0 Global Assembly Cache (GAC). The Commerce Gateway Service, however, by default runs on .NET Framework 2.0 and looks for assemblies in the .NET Framework 2.0 GAC. To work around this error, you can place the assemblies used by the receive pipeline in the .NET Framework 2.0 GAC.
Источник: http://feedproxy.google.com/~r/Micro...talk-2010.aspx
Часовой пояс GMT +3, время: 23:23.
