Старый 23.02.2011, 14:11   #1
mbsturk: Dynamics AX 2009 Workflow Setup
Источник: http://mbsturk.blogspot.com/2011/02/...low-setup.html
Microsoft Dynamics AX 2009 WorkFlow can cause an error when setting up a workflow on Win2008R2.
If you receive this error when you run Workflow infrastructure configuration wizard:
The request failed with HTTP status 405: Method Not Allowed.
Then you should change the Application pool for your workflow (which is by default MicrosoftDynamicsAXWorkflow50) to enable 32 bit applications:
semanticax: Dynamics AX 2009 Installation - Application Blog bot DAX Blogs 0 22.12.2010 08:11
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Часовой пояс GMT +3, время: 11:01.
