Старый 04.01.2011, 20:11   #1
emeadaxsupport: You get a Script Error when viewing Role Centers (deployed on SharePoint 2010) in a Microsoft Dynamics AX 2009 Client
Источник: http://blogs.msdn.com/b/emeadaxsuppo...09-client.aspx
Consider the following scenario:
- You have successfully deployed Microsoft Dynamics AX 2009 Role Centers and Enterprise Portal on a server running SharePoint 2010
- Your AX 2009 Application build is as per the SharePoint 2010 compatibility hotfix KB2278963 (5.0.1500.3191) or you have Hotfix Rollup 6 deployed (5.0.1500.3761). Check the AOT -> Classes -> SysHotfixManifest class to see if hotfix 2278963 is deployed
- One of the web parts used by the Role Center is the Business Overview web part (displaying KPIs)
- The Role Centers display fine without error using Internet Explore 6 and above, however you get the following pop-up Script Error when browsing the Role Centers in the AX 2009 Client, in this case from the business Overview web part:
(error in text):An error has occured in the script on this page.
Line: 1074
Char: 1
Error: 'businessOverviewWebParts.get_WebPart(...)' is null or not an object
Code: 0
URL: http:///Enterprise%20Portal/RoleCent...&RUNONCLIENT=1
Clicking on the Yes button in the pop-up error will still allow you to view the Role Centers as normal.
This has also been reported as an issue that you will experience when using the Refresh 4 Demo Virtual PC's
RESOLUTION:
This issue has now been resolved in AX 2009 Application hotfix KB2483518 which contains updated webparts. Please contact Microsoft Support to request this fix.
NOTE: Once the hotfix is installed you need to run AXUPDATEPORTAL.EXE with relevant switches to update the Enterprise Portal Site with the new EP webparts. This application hotfix replaces the application fix bundled inside KB2278963, see further information section below.
Further information:
You can induce a similar issue when browsing the Role Centers when using Internet Explorer 6.0 and above by enabling the Internet Explorer advanced option "Display a notification about every script error"
The hotfix contains a file called kb2483518_syp_syp.txt file which cotains the following additional information:
Release details for KB2483518
The following application objects were modified as part of this fix:
/web/web files/web parts/axwebparts_cab.xpo
/web/web files/web parts/webwebpart_axwebparts_cab.xpo
The following application objects are included due to application dependencies:
/classes/global.xpo, method: getallcompanies()
/classes/sysepdeployment.xpo
/classes/sysepdeployment.xpo, method: classdeclaration()
/classes/sysepdeployment.xpo, method: clrgenerateproxies()
/classes/sysepdeployment.xpo, method: getsharepointtemplatepath()
/classes/sysepdeployment.xpo, method: getsharepointtemplatepathdotnet()
/classes/sysepdeployment.xpo, method: getsharepointtemplatepathwin32()
/classes/sysepdeployment.xpo, method: ismossinstalled()
/classes/sysepdeployment.xpo, method: issharepointversion12()
/classes/sysepdeployment.xpo, method: new()
/classes/sysepdeployment.xpo, method: validatelanguage()
/classes/websession.xpo, method: renderscriptblock()
/web/web files/static files/axsearcharea_ascx.xpo
/web/web files/static files/axsearchresultswssv3.xpo
/web/web files/web controls/hrmepabsencerequest.xpo
This hotfix includes the following encompassed fixes:
KB2251978
KB2278857
KB2278963
KB2289365
KB2292391
KB2293433
KB2410532
KB2462529
KB2469643
KB958508
KB959111
KB960048
KB960158
KB971176
KB971185
KB973699
KB975842
KB977800
KB979296
KB982317
--author:Anup Shah--editor:Anup Shah--date: 04/Jan/2011
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
jinx: Microsoft Dynamics AX 2009 SP1 und Microsoft SharePoint 2010 Blog bot DAX auf Deutsch 0 17.08.2010 00:06
emeadaxsupport: Checking Database entries after restoring a Microsoft Dynamics 2009 SQL Database to another Domain or Environment Blog bot DAX Blogs 0 18.02.2010 23:05
Часовой пояс GMT +3, время: 07:08.
