Старый 15.07.2011, 00:13   #1
sjakalax: SysGlobalCache extended
Источник: http://sjakalax.blogspot.com/2011/07...-extended.html
hi,
I've had several occations where I was using the sysGlobalCache method for caching purposes.
Great class for caching or - combined with the info and application classes - exposing info throughout the whole application. Only ... the owner needs to be a string and once a value is added; all other values for that owner have to be of the same type. Sometimes I want to use an int as owner or store different types with the same owner.
So this would not be possible:
myGlobalCache.set('myowner', 'key1', 'value_x');
myGlobalCache.set('myowner', 'key2', 1234);
because 'value_x' is a string and 1234 is an integer value.
Same story for the code below:
myGlobalCache.set(myClass, 'key2', 'value_y');
Because the owner (myClass) in this case is not a string, but a custom class.
That's why I created an extended version of the sysGlobalCache object that can accepts different types for the values with the same owner and takes an optional parameter (default Types::String) for the owner type.
Haven't benchmarked it but I'd expect a slight performance penalty because of some extra logic.
You could even take it a step further and replace the sysGlobalCache in the info and/or application classes.
XPO containing the class can be downloaded here.
Enjoy!
Kurt Hatlevik: Extended ATP (Available to Promise) Blog bot DAX Blogs 0 18.04.2011 23:11
emeadaxsupport: Kerberos Authentication Error Code: 0x7 KDC_ERR_S_PRINCIPAL_UNKNOWN Extended Error: 0xc0000035 KLIN(0) Blog bot DAX Blogs 0 09.11.2010 19:10
emeadaxsupport: Passing UtcDateTime values in extended query syntax Blog bot DAX Blogs 0 10.05.2010 21:05
AX UK: Extended Support for Microsoft Dynamics AX 3.0 Blog bot DAX Blogs 0 10.12.2008 20:05
Microsoft Dynamics CRM Team Blog: CRM Accelerators – Part VI – Extended Sales Forecasting Accelerator Blog bot Dynamics CRM: Blogs 0 18.09.2008 02:17
Часовой пояс GMT +3, время: 12:30.
