Старый 01.07.2010, 22:07   #1
Kashperuk Ivan: Tutorial: Brief description of ways to close a form in AX
Источник: http://kashperuk.blogspot.com/2010/0...f-ways-to.html
We had this question asked on one of the internal AX forums, and Michael Fruergaard wrote a short description of each method you can use.
Re-posting it here with some extra comments, so that new developers can read and understand, when to use what method.
There are “only” 5 ways to close a form:
  • Close - close the form. Similar to the 'X' button.
  • CloseOK – close the form, and set the OK flag – called by the Commandbutton::Ok
  • CloseCancel – close the form, and set the Cancel flag – called by the Commandbutton::Cancel
  • CloseSelectRecord – close the lookup form, and set return record
  • CloseSelect – close the lookup form, and set return value
The below methods (note their names are in past-tense) are used to determine if or how a form was closed:
  • Closed – Returns true, if the form is no longer open
  • ClosedOK – Return true, if the form was closed by the user clicking ‘OK’
  • ClosedCancel – Returns true, if the form was closed by the user clicking ‘Cancel’
Finally, CanClose() is called before any of the close methods get called. If CanClose() returns false, the form is not allowed to close.
Старый 02.07.2010, 14:30   #2
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
Алексей задал вопрос в комментариях, приведу ответ и здесь для общественности
Hi,
What about infolog.close() method?
Regards,
Alex
Ответ:
Infolog.close() is a special method, called from the kernel (through infolog.formNotify()), when super() is called inside the close() method.
It does not actually do anything visible, simply updates some global variables for lastActiveForm and document handling.
За это сообщение автора поблагодарили: alex55 (1).
Kashperuk Ivan: Tutorial: refresh, reread, research, executeQuery - which one to use? Blog bot DAX Blogs 20 04.04.2017 13:23
Kashperuk Ivan: Casing and text search/comparison tutorial Blog bot DAX Blogs 6 25.02.2010 15:41
Kashperuk Ivan: Lookup form returning more than one value Blog bot DAX Blogs 0 29.01.2010 18:05
Kashperuk Ivan: List panels in Dynaics AX - a short description of SysListPanel class Blog bot DAX Blogs 1 21.10.2007 22:51
Kashperuk Ivan: Dynamics AX Tutorials - Tutorial 2 - Classes\Box Blog bot DAX Blogs 0 25.04.2007 22:23
Часовой пояс GMT +3, время: 14:16.
