Старый 06.05.2010, 03:16   #1
emeadaxsupport: HTTP 401 Error when trying to deploy/create an Enterprise Portal site on a load balanced farm using a hardware load balancer
Источник: http://blogs.msdn.com/emeadaxsupport...-balancer.aspx
We came across an issue where two WSS 3.0 servers were setup in a sharepoint farm (Contoso01 & Contoso02) and a load balanced web site/clustered web site was created (http://contoso/) successfully (uses a host header). They were using a hardware load balancer and not using Windows Network Load Balancing. Servers were running Windows Server 2008 (however that is not important).
When trying to create/deploy a Microsoft Dynamics AX 2009 Role Centers and Enterprise Portal site from the first node (Contoso01) of the cluster and using the load balanced website url, we get the following error:
The Web site http://Contoso/sites/DynamicsAx was not created correctly.
The remote server returned an error: (401) Unauthorized.
System.Net.WebException
at System.Net.HttpWebRequest.GetResponse()
at Microsoft.Dynamics.Framework.Portal.Deployment.EPFeatureReceiver.CreateAxSitesAndPages(SPWeb site)
at Microsoft.Dynamics.Framework.Portal.Deployment.EPFeatureReceiver.ProvisionAxSite(SPWeb site)
As part of troubleshooting we had followed the advised given on creating the BackConnectionHostNames registry entry as per blog titled: Installing Dynamics AX 2009 Enterprise Portal on a web site that has Host Headers configured, however that still did not work.
The issue was that it was failing to copy the portal files from the AOT to the cluster servername. The cluster name, contoso resolves to the hardware load balancers ip address as you would expect. However it needs to copy the files to the actual cluster node.
To workaround the issue, we created a host entry on the first node, which mapped the cluster hostname, Contoso, to the local ip address of the node. So for example, if node 1, Contoso01, servers ip address was 192.168.0.1 and this was the ip address mapped to the http://contoso/ web site, then we created a hostname contoso mapped to this address.
Next we first deleted the partially created site collection due to the original failure. Then we were able to create an Enterprise portal successfully on http://contoso/ address.
emeadaxsupport: How to change authentication of an existing Microsoft Dynamics AX 4.0 Enterprise Portal (EP) site to use IIS Basic Authentication Blog bot DAX Blogs 0 29.03.2010 21:05
emeadaxsupport: How to manually deploy ODC Files to Microsoft Dynamics AX 2009 Enterprise Portal Blog bot DAX Blogs 0 17.02.2010 21:07
emeadaxsupport: The mystery of blank Enterprise Portal pages Blog bot DAX Blogs 0 28.07.2009 16:05
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
JOPX: Integrating MOSS 2007 and Dynamics AX Part II - installing and configuring Dynamics AX Enterprise Portal Blog bot DAX Blogs 0 02.03.2008 06:42
Часовой пояс GMT +3, время: 06:03.
