axaptapedia: FtpWebRequest
Источник: http://www.axaptapedia.com/FtpWebRequest
============== Summary: New page: Since version 4 and in version 2009 you may use the .NET framework inside Dynamics AX. The FtpWebRequest class in the System.Net namespace handles FTP communication like upload, download, ... Since version 4 and in version 2009 you may use the .NET framework inside Dynamics AX. The FtpWebRequest class in the System.Net namespace handles FTP communication like upload, download, delete files and retrieve a list of files in a directory, etc. ==Upload File== X++: static void uploadTestFile(Args _args) { object ftpo; object ftpResponse; System.Net.FtpWebRequest request; System.IO.StreamReader reader; System.IO.Stream requestStream; System.Byte[] bytes; System.Net.NetworkCredential credential; System.String xmlContent; System.Text.Encoding utf8; System.Net.FtpWebResponse response; ; // Read file reader = new System.IO.StreamReader("C:/test.xml"); utf8 = System.Text.Encoding::get_UTF8(); bytes = utf8.GetBytes( reader.ReadToEnd() ); reader.Close(); // little workaround to get around the casting in .NET ftpo = System.Net.WebRequest::Create("ftp://ftp.company.com/dir/test.xml"); request = ftpo; credential = new System.Net.NetworkCredential("user","password"); request.set_Credentials(credential); request.set_ContentLength(bytes.get_Length()); request.set_Method("STOR"); requestStream = request.GetRequestStream(); requestStream.Write(bytes,0,bytes.get_Length()); requestStream.Close(); ftpResponse = request.GetResponse(); response = ftpResponse; info(response.get_StatusDescription()); } Источник: http://www.axaptapedia.com/FtpWebRequest
Теги |
ftp, загрузка |
Тема | Ответов | |||
axcoder: PowerShell + Ax | 1 | |||
axaptapedia: Load Web Documents | 1 | |||
axcoder: AxPath is supported by axaptapedia | 0 | |||
axaptapedia: ElementVersionTrack | 0 |
Опции просмотра | |
