Старый 08.11.2008, 02:11   #1
axcoder: AxPath pugin for Tabax which works with Ax3, Ax4, Ax2009
Источник: http://axcoder.blogspot.com/2008/11/...orks-with.html
Now you can download AxPath.dll (with sources) which works with Ax 3, Ax 4, Ax 2009. Previously it worked only if Ax3 was installed.
Ivan fixed it to work with Ax2009, now I have extended it to probe registry keys for Ax2009, Ax4, Ax3 (in that particular order) and work with the version found first.
If you do not know what AxPath and Tabax are - look at http://axaptapedia.com/AxPath, http://axaptapedia.com/Tabax
AxPath plugin originated by AndyD from http://axforum.info
axpath, tabax, ax2009, ax3.0, ax4.0
axcoder: Sidax & Tabax for Ax2009 Blog bot DAX Blogs 4 17.02.2021 19:13
Ошибка в InterCompanyInventDim (AX4 и AX2009) Bishop DAX: Программирование 2 17.12.2008 15:08
AX2009 и AX4.0 совместимый код. Как? Alex_KD DAX: Программирование 6 08.05.2008 01:10
axcoder: AxPath is supported by axaptapedia Blog bot DAX Blogs 0 11.05.2007 10:00
axcoder: AxPath integration with browser email etc Blog bot DAX Blogs 0 26.04.2007 16:40
Часовой пояс GMT +3, время: 23:31.
